Identify Widget for FlexViewer 2.1
106883
266
09-23-2010 11:34 AM
RobertScheitlin__GISP
All,
   I have been waiting for the Final release of the FlexViewer 2.1 before I started to push out some widgets I have been working on.
Here is my Identify Widget for Flex Viewer 2.1. I have tested to ensure proper functioning with FlexViewer 2.1 and am now releasing it to you since the API Team did not get one into the FlexViewer.
Here is the link:
http://www.arcgis.com/home/item.html?id=39cf66d58c234279ba728c50461a1a89
More FlexViewer 2.1 widgets to come stay tuned...
EmilyLaMunyon
I removed the identity widget from my config.xml and the cursor is still there and now it the winodw says the operation is not supported by this service. Do you still want me to post anything?
Thanks, Emily
Emily,
   Once you removed it from the config.xml did the button of the identify widget go away?
EmilyLaMunyon
No, it is still there.
Emily,
   Then you need to clear your browsers cache.
EmilyLaMunyon
I cleared the cache twice and it is still there. Maybe I am not sure what you mean by identity button. Are you talking about the blue i in the identity window?
Thanks!
Emily,
    Yep, I am referring to the blue identify button that was added to your application when you added my widget to your app. Once you remove the identify widget element from your config.xml you should no longer see the blue i button in your app. Are you using the compiled or uncompiled version?
EmilyLaMunyon
The compiled version.
Oops, after clearing it a couple of more times it did disappear. Sorry about that, I am not sure why it took so many tries. So, now the identity button and window are gone from my viewer. Should I attach my identitywidget.xml?
Thanks!
Emily,
    Did the busy cursor go away?
If it did then attach your config.xml and your IdentifyWidegt.xml.
EmilyLaMunyon
Yes, the cursor went away.
Here are my files.
Thanks so much!
Emily,
   I don't see anything wrong. Of course the config.xml you send was the one you deleted the identify widget from so I can't see if you had any issues there. Try adding it back using this code
<widget label="Identify" left="330" top="80"
                icon="assets/images/i_info.png"
                config="widgets/Identify/IdentifyWidget.xml"
                url="widgets/Identify/IdentifyWidget.swf"/>
And let me know the result.
