Identify Widget for FlexViewer 2.1
106913
266
09-23-2010 11:34 AM
RobertScheitlin__GISP
All,
   I have been waiting for the Final release of the FlexViewer 2.1 before I started to push out some widgets I have been working on.
Here is my Identify Widget for Flex Viewer 2.1. I have tested to ensure proper functioning with FlexViewer 2.1 and am now releasing it to you since the API Team did not get one into the FlexViewer.
Here is the link:
http://www.arcgis.com/home/item.html?id=39cf66d58c234279ba728c50461a1a89
More FlexViewer 2.1 widgets to come stay tuned...
JakeAalfs
Rob,
I have included screenshots of REST Services and each mapserver's layers.
Jake,
   I am not sure if the issue is with the Map Services layer names I have not done any testing with services that the author did not have good aliasing setup. I would try opening the map service and giving your layers aliases and then republishing and clearing your rest service cache and try again.
JakeAalfs
Ok Rob. I'll give that a try and let you know when I find a solution.
Jake
guchenghuang
ReferenceError: Error #1056: �?��?为 com.esri.viewer.WidgetTemplate �??建�?�?� selectedTitlebarButtonIndex�??
at widgets.Identify::IdentifyWidget/showStateResults()
at widgets.Identify::IdentifyWidget/identifyFeatures()
at widgets.Identify::IdentifyWidget/drawEnd()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at com.esri.ags.tools::DrawTool/map_clickFirstHandler()
at mx.core::UIComponent/dispatchEvent()
at com.esri.ags::Map/mouseUpHandler()
This Widget couldn't work�?what's the problem�??
gucheng,
   This widget requires FlexViewer 2.1 like it's title states
EmilyLaMunyon
Robert,
I have this wodget working well, however, how do I have more than one field appear in the pop-up winodow above the feature? Right now, I am only able to get one field to show.
Thanks!
Emily,
   Are you using the latest version 2.1.6? There was an issue with earlier version that resulted in only the title field displaying in the results.
EmilyLaMunyon
Yes, I just verified that I am using version 2.1.6.
Emily,
   Post your IdentifyWidget.xml then.
EmilyLaMunyon
Here it is..thanks again for your help:)
