Identify Widget 3.6.7: Problems with private services
7780
10
09-18-2014 06:19 AM
PedroGarcia
Hi Robert,
I've a private service with mapping and feature access capabalities enabled. Testing your widget with a layer based on that service (type="feature" with token) and using your original IdentifyWidget.xml, I got  'No results found' message. However, when I setup that layer at IdentifyWidget.xml file, as follow:
        <layer>
            <name>Parcelas Edicion</name>
            <id>0</id>
            <url>http://myserver/arcgis/rest/services/ESARM/ESARM_ALTIPLANO/FeatureServer</url>
            <fields>
                <field name="created_user" alias="created_user"/>
                <field name="created_date" alias="created_date"/>
                <field name="last_edited_user" alias="last_edited_user"/>
                <field name="last_edited_date" alias="last_edited_date"/>
            </fields>
            <links/>
            <zoomscale>2000</zoomscale>
            <forcescale>true</forcescale>
        </layer>
the viewer display the login screen (see attached file) as soon as I active your widget, and even entering correct credentials I always got 'No results found' message. Any idea?
Besides, including that layer in config.xml as type=dynamic and in IdentifyWidget.xml  filtering some fields, the login window is displayed as well. Any idea?
Thanks.
RobertScheitlin__GISP
Pedro,
   Go ahead and make this thread as answered by clicking on the "Correct Answer" link (the one with the little green star) and I will took into your second question as soon as I can.
