Identify Widget 3.6.2 for Flex Viewer: raster layer names will not display
25768
32
01-21-2014 01:32 PM
BarnabyRockwell
Using the 3.6.2 version of the Identify Widget, I cannot get names of attributed, ERDAS Imagine (.img) raster layers to display when I click on a pixel in the Flex app to identify. In the 3.0.2 version of the widget for Flex Viewer 3.0, the layer name would be displayed for these raster layers. How can I get the layer name to be displayed along with the other results? I am using ArcGIS 10.2 for Server and Flex Viewer 3.6, on Windows Server 2008 R2 x64. I have not installed the Flex API, just the Flex Viewer.
Behavior is the same with widget version 3.5.1 for Flex Viewer 3.5.
Layer names for vector layers are displayed with Identify results, just not the layer names of the Imagine .img files. In Widget settings, if I try and add a layer from one of these rasters, the services are seen, but no "addable" features are shown, so I cannot add them.
In my current xml configuration for the widget, I completely removed the <layers> section. So there is no layer info in the xml for any layer. Everything seems to work fine except for the .img layers for which no layer names are displayed.
This image shows identify results on one of the .img files using Identify widget 3.0.2 in Flex Viewer 3.0, using ArcGIS for Server 10.0 (sp5), in Firefox:
[ATTACH=CONFIG]30682[/ATTACH]
This image shows identify results on one of the .img files using Identify widget 3.6.2 in Flex Viewer 3.6, using ArcGIS 10.2 for Server, in Firefox:
[ATTACH=CONFIG]30683[/ATTACH]
Thank you in advance...
by Anonymous User
Not applicable
Original User: rscheitlin
Barnaby,
   Not in that old version.
BarnabyRockwell
Ok.  Thanks again!  🙂
by Anonymous User
Not applicable
Original User: Pingu
Robert,
thanks a lot, I'll test with this.
Robert,
Finally turned out the problem was with the map service. Feature and raster layers were in together in one map service. After publishing two different ones, the features and the rasters separately, the widget was working perfectly and reporting the values from polygons and underlying pixels at the same time.
thx again
