hyperlinking from flexviewer to googlemaps
1711
04-04-2011 10:50 AM
glennhazelton
i am wondering if there is a set of parameters like {x} {y} or {lat} {lon) that i could use to open google maps or bing at the same location as the center of the flexviewer 2.2 display.
BjornSvensson
Esri Alum
Yes, you can get the center of the map with map.extent.center.
There are examples for parsing the x and y into latlong in both the code for the Coordinate Widget as well as in this API sample:
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=ReadURL
FrankRoberts
I also have the capability in the Street view and more widget.  The update later on this week will allow for a default selection of what you view when you click on the map, such as a google map.
http://www.arcgis.com/home/item.html?id=dc56d2ab11534d24a5559ea9dc8f5119
Frank
