Hyperlink In Identify Widget
3630
02-18-2014 08:17 AM
by Anonymous User
Not applicable
Original User: walterdziuba
After installing the custom Identify widget into our Flex 3.6 viewer, whenever map features are selected and the resultant "Results Found" displays, there's a small red arrow hyperlink at the bottom of each of the results.
I thought it was the layer properties in my original .mxd file where I had checked off "Show content for this layer using the HTML Popup tool", but after I removed this and republished the map service, the red arrow hyperlinks still appear.
How can this be resolved?
Walter
[ATTACH=CONFIG]31555[/ATTACH]
RobertScheitlin__GISP
Walter,
   The only reason for that to be there in the results is if you configured a link for those layers. Are you using App Builder or manually configuring the widgets xml?
Walter,
by Anonymous User
Not applicable
Robert,
Everything is done with the App Builder.
Walter
WalterDziuba
Robert,
You're bang on again.  There were links created under the widget's initial configuration of the endpoints, with the "Include" to Links Fields.
Thanks again for your help.
Walter
