How to set MapRotation in FLexViewer 3.1
1346
01-15-2013 02:19 PM
YasnaiaFlorentino
Hi all,
I've downloaded the arcgis api  for flex 3.1 (uncompiled), and the arcgis viewer flex 3.1 (uncompiled).
And I'm working with Flash Builder 4.6.
I am trying to set map rotation on my source code for FlexViewer. How can I do that?
On my index.mxml I am getting errors.
Thank you
RhettZufelt
MVP Notable Contributor
This setting can now be done in the main config.xml in the map tag:
 <map rotation="270" wraparound180="true" initialextent="-14083000 3139000 -10879000 5458000" fullextent="-20000000 -20000000 20000000 20000000" top="40" addarcgisbasemaps="true">
R_
YasnaiaFlorentino
Thank you for the answer.
Changing the config.xml file <map rotation ="270"> tag  it really rotates the map, but what I am
really looking for is the rotation wheel where you can rotate the map and
reset for the original setting (North).
Thank you
AnthonyGiles
Honored Contributor
Yasnaia,
Have a look at this sample, I think it is what you are after:
http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Rotate_Map/01nq0000008s000000/
Regards
Anthony
