How to access Bing Maps
6312
13
10-01-2010 11:18 AM
ChrisMack
I am using ArcServer 10 and the ArcGIS Viewer for Flex 2.1.
What should I use as the REST endpoint URL for Bing Map data?
LonSharp
I'm still new to this, Bruce, but it sounds like you seeing the bing roads layer (the one referenced with the tag <layer label="Bing" type="bing" visible="false" style="road" culture="en-US" /> )
Make sure that the visibily is set to false, and the visibility for one of the other two - aerials or hybrid - is set to "true".
(note that I didn't actually add all three tags to my config file, just the hybrid)
AnshulMantri1
Is it still possible to project bing maps using flex api lib v 1. I understand in olderversion of flex it needs a handler page with userID and pwd. Does it allow the projection of bing maps to other than wgs84.
regads
anshul
AnshulMantri1
HI Robert,
I am using flexviewer 3 with flex api 1.3.
The tage is
<esri:VETiledLayer id="veLayer"     tokenURL="" />.
I want to understand what will this tokenURL contain?
If its a handler page then it will need user ID and password.
But at the same time i registered at "https://www.bingmapsportal.com"  it gave me a key to use. I can use this key in Flex 4 and not in Flex 3. Could you please suggest how to use the key for flexviewer3.
thanks
Anshul
AnshulMantri1
Documentation for using bing Maps can be found at:
http://help.arcgis.com/en/webapps/flexviewer/help/Default.htm#CSHID=layer_tag.htm|StartTopic=layer_t...
help for using Bing in LocateWidget can be found here:
http://help.arcgis.com/en/webapps/flexviewer/help/Default.htm#CSHID=widgets%2Flocate_widget.htm|Star...
See it in action at:
http://help.arcgis.com/en/webapps/flexviewer/live/index.html?config=../samples/config-bing.xml
config file for the above application is at:
http://help.arcgis.com/en/webapps/flexviewer/samples/config-bing.xml
Config file for the Locate Widget used in above application is  at:
http://help.arcgis.com/en/webapps/flexviewer/live/widgets/Locate/LocateWidget_Bing.xml
More info on getting Bing key can be found at:
http://help.arcgis.com/en/webapi/flex/help/index.html#ve_gettingstarted.htm#
The links for Bing map documentations are not working, can someone please update the new links..!!
