Help on Advanced Drawing Widget
1891
09-08-2013 07:53 PM
azzamwahab
I use Advanced Drawing Widget for FV3.0 version. The widget is fantastic!! Except the hyperlink to a web location when the user clicks the graphic doesn't work. The path links to an image doesn't work either. That's one thing.
The other thing, I would like to make some modification on the code, to allow user Load & Display the local image. I found a sample from this guy URL . From my observation, there are two mxml files involve here; SENZ_DrawAdvanceWidget.mxml and GraphicEditor.mxml. If I use the sample code and modify GraphicEditor.mxml, how do I call back inside SENZ_DrawAdvanceWidget.mxml so that when the graphic is clicked on the map, the image will show inside the info popup.
Thanks.
