HeaderControllerWidget - Are there any tags to help improve search results
6039
02-04-2015 03:15 AM
JonHawkins
Hi
Is there any way to improve the search results of the HeaderControllerWidget so that it only returns records that 100% equal the search value entered, rather than ranking other records that contain the value higher in the results
Here is the problem:
I have the widget set to search one layer within one map service only. The layer contains 55,000+ Planning Applications.
The service is set to search only one varchar field (Application_Number).
                <searchfields>Application_Number</searchfields>
The problem is if I enter the application number 00226 the HeaderControllerWidget selects records that contain 00226 eg. WC002260 , 7500226 and does not display the record that only has this value.
If I use the search widget and enter 00226 the correct record is selected. This is no doubt because I can specify the expression syntax to be <expression>Application_Number= '[value]'</expression>
Does anyone know if it is possible to define a similar syntax in the HeaderControllerWidget.xml
Please Note: The reason I want to get this working with HeaderControllerWidget is because I have an external Planning application system that passes a URL to my FlexViewer to conduct the search ie.... websites/FlexViewer/index.html?search=00226 and at present it gives incorrect results.
Jon
AnthonyGiles
Honored Contributor
Correct you need to rebuild geolocators if your base data changes which is a bit of a pain.
Another option could be to use Roberts Esearch widget, this allows you to fire a search using a URL parameter:
ArcGIS Viewer for Flex
rscheitlin/eSearch · GitHub
AnthonyGiles
Honored Contributor
Jon,
Instead of searching your against your maps service you could create a geocode service for your data and geolocate against that instead. Changing the sensitivity settings <minscore> in the geocode service may narrow your search results.
Regards
Anthony
P.S. You may get more visibility of your question by the right people if you move your thread to the flex viewer space ArcGIS Viewer for Flex
JonHawkins
Anthony
Thanks for the suggestion and that is a good idea. Can I just check though am I right in thinking that the GeoCode service is not dynamic. ie. As new Planning Applications are added they wont be seen by this service.
PS: I have moved the thread to ArcGIS Viewer for Flex (apologies I am a first time poster)
Jon
AnthonyGiles
Honored Contributor
JonHawkins
Anthony
Thanks. Just tested eSearch widget and that gives me the functionality I need.
Many thanks for your time.
Jon
