Header Controller search scroll bars
894
06-25-2014 12:05 PM
GeraldStanuch
Flex viewer 3.1 had a vertical scroll bar for the Header Controller search box.  Versions after that only show 6 results and no vertical scrollbar.  Can I add a vertical scroll bar to the Header Controller search box in Flex Viewer version 3.6 like the way it used to be in version 3.1?  Attached is the current help file which shows the vertical scrollbar, but if you try the actual viewer, it has no scrollbar.
AnthonyGiles
Honored Contributor
Gerald,
You can change the <maxlocations> Tag in the widget config to return more locations, if you set this to more than 6 which is the default a scroll bar will display
Regards
Anthony
AnthonyGiles
Honored Contributor
Gerald,
Regards
Anthony
