All,
Here is the next installment to my long list of widgets. I never really wanted to add to the list of several Street View Widgets, but as it's predecessors have lacked updating when new version of Flex Viewer are released and me wanting to add more features, I finally decided to do one myself.
The Google Street View Widget version 3.3 for Flex Viewer 3.3 allows you to view Google Street View Panoramas in a popup window. The widget use Google Maps API Version 3 and has almost all the API options for the Street View Panorama that are available in the API configurable in the widgets xml. A lot of attention has gone into the UI (User Inferface) and UX (User Experience) of this widget and a lot of cross browser testing has been done. Tested on Safari for windows 5.1.7, Internet Explorer 9, Opera 12.15, FireFox 21.0, and Chrome 27.0.1453.110 m.
Configurable features include:
* hidestreetviewvwidowwhenminimized - This is a true or false value and determines if the graphic on the map and the Google Street View window are hidden when the widget is minimized.
* width - The width of the popup widow that is opened.
* height - The height of the popup widow that is opened.
* apikey - The Google Maps API Key that you must obtain to use this widget.
https://developers.google.com/maps/documentation/javascript/tutorial#api_key
* addresscontrol - is a true or false value and determines if the Google Street View Address Control is visible.
It has an attribute of controlposition that defines where in the popup window the control is placed.
* clicktogo - is a true or false value and determines if the Google Street View will move to the location clicked.
* disabledoubleclickzoom - is a true or false value and determines if the Google Street View will zoom into the
location on the panorama where the user double clicks.
* imagedatecontrol - is a true or false value and determines if the Google Street View will display the date of the
panorama image was taken along the bottom of the window with the copyright info.
* linkscontrol - is a true or false value and determines if the Google Street View will display the movement arrows
and street names on the panorama for navigation purposes.
* pancontrol - is a true or false value and determines if the Google Street View pan Control is visible.
* zoomcontrol - is a true or false value and determines if the Google Street View zoom Control is visible.
It has an attribute of controlposition that defines where in the popup window the control is placed and a
controlstyle attribute that determines the size of the control.
* All text that the widget uses is configurable in the xml to allow for internationalization of the widget.
So here it is: http://www.arcgis.com/home/item.html?id=b4259b1cf73e4fa3b04e7bdf75fee29b
<widgetcontainer layout="float">
<widget label="Google Street View" width="380"
preload="minimized"
config="widgets/StreetView/StreetViewWidget.xml"
icon="widgets/StreetView/assets/images/i_gsv.png"
url="widgets/StreetView/StreetViewWidget.swf"/>
</widgetcontainer>
