Google Street View for the Flex 3.0 API
4736
14
09-07-2012 10:32 AM
andrewj_ca
Just posted the code for the updated 3.0 API for my Street View Widget.  I have't had a chance to do the install instructions yet but I'm sure most of you will figure it out.  Both source and compiled versions are included.  Cheers,
http://www.arcgis.com/home/item.html?id=b721eec8dde442559e9c17acecd22188
RobertScheitlin__GISP
Andrew,
   You will want to go back into your content tab in ArcGIS online and edit your item to be Purpose: configurable and not Purpose:                   Code Sample, as it has now disappeared from the Flex Viewer code gallery because of this.
*EDIT* Must be the missing "widget" and "flexviewer" tags also because it is still not in the Flex Viewer Code Gallery!
andrewj_ca
Thanks for the tip. Done.
DavidCaussin
Hi Andrew,
Thanks for this widget, it work fine except with the WKID that i use (31370).
I have a difference of 100-200m.
Is there a solution that that i can try?
Thanks in advance.
Mercator
andrewj_ca
Sounds like going from 4326 to 31370 on the fly might be troublesome.  I'm not familiar with Belgian Lambert but it may require a transformation to go from one to the other.  Any Datum/Projection specialists out there want to weigh in?
Andrew
RyanWendt
Hi Andrew,
I added the compiled version to a Flex Viewer following directions in the readme file. Tool displays and I can add a point to the map, but the street view window doesn't show up at the bottom of the page. Any ideas?
Ryan
andrewj_ca
Hi Andrew,
Ryan
ryanwendt,
Did you overwrite the index.html with the one I supplied?
Corbinde_Bruin
ryanwendt,
I had the same issue and this fixed it. I had previous skipped that step because I didn't know what it did, and that scares me.
andrewj_ca
cdebruin,
The altered index.html does several things.  First, it adds the Google API to the application and the required JavaScript.  Second, it gives the flash object a standard name so that it can be referred to later in the code.  Nothing scary there.
Andrew
RyanWendt
ryanwendt,
Yes I did overwrite the index.html with yours.  Funny thing I noticed is that the widget works in the Preview mode for the Flex App Builder.  I can't get it to work in IE or Firefox though.
