GeoRSS Widget ATOM Feed
6513
10
10-26-2010 01:58 PM
JoshuaKeller
I am attempting to use an ATOM feed with the 2.1 GeoRSS widget and I seem to be having some troubles. It displays the points correctly but I'm not able to get the title etc. to display, it just uses the widget title as the default. I know that the feed is good because I can recompile the Reading GeoRSS feeds from the ESRI sample and replace the Flickr URL with my feeds URL and that loads correctly, displaying all of the content and the title. Is there a difference in the config file for ATOM feeds or do I still just put the list of fields and title field? Is anyone else having this problem?
Josh
JanieGoddard
Hi Jeff,
   I was not able to get the new atom feed to list correctly either using the FlexViewer 3.0 compiled version.
   I upgraded this FlexViewer to 3.1 and used the below source and now it works perfect!
    <source>http://earthquake.usgs.gov/earthquakes/feed/atom/2.5/week</source>
Hope this helps,
Janie
