Geoprocessing Widget drop down list issue
1182
04-20-2012 06:30 AM
MatthewFrank
I published a geoprocessing service which includes a string input parameter with a defined choice list (see attachment). When I use the service in ArcMap and ArcGIS Explorer I get a dialog box with a corresponding drop down list. When I use this service with the Geoprocessing Widget, I only get a text input box. Is there a way to configure the Widget to recognize the choice list from the service as well?
AnthonyGiles
Honored Contributor
Matthew,
Are you using the geoprocessing widget out of he box, if so I think you will have to specify the drop down list in the config file manually using the <choicelist> tag, see:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#//01m30000002s000000
Unfortunatly I don't think there is a way for the widget to automatically pick up your values,
Hope this helps
Anthony
