Geoprocessing Widget Date Field
781
05-14-2014 12:05 PM
AndrewRadford
Hi,[ATTACH=CONFIG]33824[/ATTACH]
I have created a geoprocessing widget and i am having some trouble with the date fields in it. The field in SDE is a datetime field but my data itself is just a date:
5/14/201400.00.0000
When i try to select data in a range i cant seem to get one specific date without putting the range from the day before.
for example i would need to put 5/13 and 5/14 to get anything on 5/14. I think it has to do with the date string being passed from the widget to the geoprocessing service. is there any way i can pass just simply the dd/mm/yyyy and remove the time from being passed.
Any help is appreciated.
Andrew Radford
