Flexviewer layer widget: remove option to expand parent layers
3420
10-23-2014 03:08 AM
LaurenWilliams
Is there a way to remove the option to expand the parent layer so that the sub layers are not visible and cannot be switched on or off? I have 4 dynamic services, each of which is a different map the user is required to print. For the purpose of standardisation and simplicity, I only want the user to be able to activate the parent layer (all sub layers under the parent would then be activated). I'm not a developer, but have had some success tweaking the widget xml files. I also downloaded the eLayerList widget, but it does not have that option.
