Flex viewer set line colour for selected feature
5477
01-07-2015 07:39 PM
KoseWong
Greetings,
I use querytask to select polyline feature, but the selected feature colour just the same of all other features in the same layer. I tried to set the colour use:
<esri:SimpleLineSymbol id="lineSymbol"
  alpha="0.4"
  color="0x0000FF"
  width="2">
But it is no effect.
I add code in querytask onResult function using
graphicsLayer.symbol = sfs;
Also no effect.
Is there an example for set colour for polyline selected feature(s), the sample I found both for polygon features.
Thanks.
RobertScheitlin__GISP
Kose,
  Here is the code fixed:
queryTask.execute(query, new AsyncResponder(onQueryResult, onQueryFault));
function onQueryResult(resultSet:FeatureSet, token:Object = null):void
      graphicsLayer.clear();
      if (resultSet.features.length == 0){
          Alert.show("No feature returned, please try again.");
      }else{
          var finalExtent:Extent;
          var stGraphic:Graphic = resultSet.features[0];
          finalExtent = Polyline(stGraphic.geometry).extent;
          resultLineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, 0x0000FF, 0.4, 2);
          graphicsLayer.symbol = resultLineSymbol;
          for each (var graphic:Graphic in resultSet.features){
              stGraphic = new Graphic(graphic.geometry);
              graphicsLayer.add(graphic);
              finalExtent = finalExtent.union(Polyline(graphic.geometry).extent);
          map.extent = finalExtent;
function onQueryFault(faultInfo:Object, token:Object = null):void
      Alert.show(faultInfo.toString());
Kose,
  Without seeing your code, all I can do is guess based on your minimal code shared. One thing that sticks out is
Normally people use sfs for a Simple Fill Symbol and not a SImpleLineSymbol. Also the graphicsLayer symbol will be ignored if the actual graphic gets a symbol assigned in the code.
KoseWong
Hello Robert,
Thanks for your explanation, sorry to provide piece of code.
The related code as follows:
      else
          stGraphic = new Graphic();
              stGraphic.geometry = graphic.geometry;
              //resultLineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, 0x0000FF, 0.4, 2); // this line no use, right?
There is no other code to set the symbol. Is there something wrong with my code?
Thank you so much.
Kose,
      }else{
KoseWong
Hi Robert,
It works! Thank you very very much!!
