Flex Viewer and Errors when Running from Flash Builder - Google Chrome - error 2148
2845
12-13-2012 09:14 AM
ionarawilson1
When I run either Flex viewer 2.5 or 3.0 directly from FB 4.6 everything is great on Firefox and IE, but I get an error when using Google Chrome. If I export release build and open the html in Chrome, it works fine but it does not work if I run directly from FB. Does anybody know why? This is my computer at home and at work I never had an issue like that before. Here are the errors
config manager
Fault code: InvokeFailed
Fault info: Error #2148
Fault details: null
viewer manager
Some error occurred. ExternalInterface doesn't work in Standalone player.
Thank you for any help!!!!
RobertScheitlin__GISP
Ionara,
   You need to Google about setting up Flash Builder to use Google Chrome "flash builder and Google Chrome".
Ionara,
ionarawilson1
Robert,
I am glad to know that that's the problem:o. I will try that when I get home! Thanks !!!
