Flex Viewer 3.0 - Secured Service using IdentityManager
6890
16
06-03-2012 09:59 PM
PanWang
I am trying to use a new function in Flex Viewer 3.0: "Edit secure service" (http://resourcesbeta.arcgis.com/en/help/flex-api/samples/index.html#/Edit_secure_service/01nq0000007...). I have already set up the configurations in ArcGIS Server and it seems working fine when I connect a map service with the right user name and password. But when it comes to multiple services, the log-in window pops up repeatedly for each services, even though they have access to the same role.
For example, when I try to use 3 services in my opreational layer:
       <operationallayers>
             <layer label="Service1" type="dynamic" visible="false"
                   url="http://localhost/ArcGIS/rest/services/Service1/MapServer"/>
            <layer label="Service2" type="dynamic" visible="false"
                   url="http://localhost/ArcGIS/rest/services/Service2/MapServer"/>
            <layer label="Service3" type="dynamic" visible="false"
                   url="http://localhost/ArcGIS/rest/services/Service3/MapServer"/>
      </operationallayers>
all the services are protected and accessible to only one role in ArcGIS server:
[TABLE="class: grid"]Service Allowed roleuser_namepasswordService1 staff staff1 staff1$Service2 staff staff1 staff1$Service3 staff staff1 staff1$
[/TABLE]
But when Flex Viewer starts, the log-in window pops up 3 times for each service, which is unnecessary for they are using the same user name and password!
Did anyone meet the same problem before, and have a solution to it ? Thanks in advance!
DasaPaddock
Hi Dasa,
I got a problem with the request POST when I log, actually, it send to the URL http://.../generateToken but I would like, like on yours, https://..../generateToken, could you explain me how to do that??
Thanks in advance,
Ben
What is the Token Service URL shown at: http://[host]/arcgis/rest/info
BenjaminMercier
Thanks for your answer. This info return the URL of the intern server of the company if I use this url request: "http://vwpfr010app134:6080/arcgis/rest/info
Authentication Information:
But we have recently installed a web adaptor to access our web applications from everywhere to this adress: https://sygdev.systra.info/arcgis/rest/info and here is the result:
From applications I use in extern, I use the second url, so I don't know why generateTokens URL don't use an https request...
I hope you understand me.
Ben
PS: I don't understand why this url is slow to answer...
DasaPaddock
Can you double-check that your application is using the web adapter URL? You can use the Chrome Dev tools to see the network requests. Also, do yo have a public URL to your app?
One problem may be that I get a SSL certificate error ("host name mismatch") when loading https://sygdev.systra.info/arcgis/rest/info
BenjaminMercier
Hi Dasa,
To answer your question:
1) Yes this application use https://sygdev.systra.info/test so it's the web adaptor URL
2) The genrate token URL use http://sygdev.systra.info/arcgis/tokens which actually not exist, I don't understand why it use that.
We'll have to buy a domain name befre having a certificate. I hope...
Ben
DasaPaddock
Hi Ben,
I found that the problem is that the JSON /rest/info response used by the app is returning the URL as just http. See the tokenServicesUrl at: https://sygdev.systra.info/arcgis/rest/info?f=pjson
This may be a server bug. It is being investigated.
Are you compiling your Viewer? If you are, I can show you how to update the code so that it doesn't use the /rest/info response.
BenjaminMercier
Hi Dasa,
Well found !!
For my job I use source code of ArcgIS Viewer For Flex, but usually, the others are publishing web app with the 3.3 application builder...
I guess it should be a parameter of the ArcGIS Server or something else to do with the web adaptor...
Thanks so much. Tell me if you have something new.
BenjaminMercier
Hi Dasa,
I found where to modify this parameter finally...
It's located in the http://yourArcGISServerURL/arcgis/admin/security/config folder. In Update I had to choose "HTTP or HTTPS" protocol or "HTTPS Only".
Thanks you Dasa to find from where I had the problem.
Ben
