Flex Veiwer-Search Widget-Only one column allowed in field name tag.
556
10-27-2010 05:30 AM
EddBlaine
I am working with the XML config to change parameters for the search widget. Basically, I would like more than one column to show up in the results pane when a query is executed. Here's my code snippet:
<layer>
            <name>Parcel Owner</name>
            <url>http://199.201.190.110/ArcGIS/rest/services/Parcels/MapServer/0</url>
            <expression>CUO1LastName = '[value]'</expression>
            <textsearchlabel>Owner Last Name:</textsearchlabel>
            <graphicalsearchlabel>Use one of the graphical search tools to select parcels</graphicalsearchlabel>
            <titlefield>CUO1LASTNAME</titlefield>
            <linkfield>WEBLINK</linkfield>
            <fields all="false">
        <field name="CUO1LASTNAME"/>
            </fields>
        </layer>
When I try to use a comma separator in the field name tag under <fields>...I get returned records with no text at all. It works OK if I just list one column name under the field tag. Any clues?
RobertScheitlin__GISP
Edd,
   All you have to do is add another field element
<field name="FIELD2"/>
</fields>
