flex random error +Fault code: 400
4670
8
06-14-2012 01:56 AM
parvazparvaz
Hi
I have a random error in my flex application:
" ....layer failed to load: Fault code: 400   Fault info: Unable to complete operation  Fault details: Invalid URL ...."
I guess this error appeared after that I installed AGS SP4. although I,m not sure.
If after this error I press F5 key, flex will load all layers normally. But this is not good for flex application.
what should I do?
Regards
A.ponker
parvazparvaz
Any solution for this problem?
MehulChoksey
Try monitoring the http traffice using http proxy tool such as firebug/fiddler/httpfox/charles to see which request is failing.
Mehul
JohnGarvey
One thing you could check is to see if the check and repair idle instances for your map services is checked and that is does this check in some reasonable time period (15 min?). These options are under the process tab of your map service.
-j
parvazparvaz
The problem exist, what should I do?
ShwetaMorkhandikar
I get the same error everyday. Refreshing the application resolves it. But not good if the users get this message whenever they start the application.
Tried Fiddler, no issue identified there. Also looked into AGS log files, none there.
GenoCarpentier
I have the same problem, too.  If I refresh, the layer loads.  I do have a lot of map services (12) to load into the map.  It is not always the same layer that fails to load.
AnthonyGiles
Honored Contributor
Geno
it also sounds like you are expriencing 'Sleeping Services' see this post for the remedy:
http://forums.arcgis.com/threads/26850-Sleeping-Server-Services-slow-to-start?highlight=Flex+Sleepin...
Regards
Anthony
ShwetaMorkhandikar
Anthony,
Tried that option but still getting an error
