eTime Widget problems with rasters
1184
05-23-2013 01:49 PM
JustinFultz
I am trying to display time enabled rasters in my flex app using the eTime widget. When doing this, the raters don't display correctly in and don't show particular colors, leaving holes or in some cases replacing the color with the another color.
I can publish a single raster as a service with the same symbology and it displays correctly. Does anyone know what might be causing this through the eTime widget?
Justin
JustinFultz
After working with this for quite some time I have found that a raster using the "Stretched" symbology type in 10.1 will display as expected. I was hoping to used the "Classified" symbology type but will have to settle for "Stretched" unless someone else has suggestions.
JustinFultz
