eSearch Widget Issue
5131
6
02-09-2015 05:39 PM
PeterKohler
I'm using the latest version of the eSearch widget and am running into an issue with layers that have geometry type of  esriGeometryMultipoint.  When I attempt the search the symbols are returned on the map, but the widget hangs.  A graphical search returns an error 1009.  I'm using the ArcGIS Flex API version 3.7.  Has any one else had this issue?  Thanks!
Pete Kohler
RTC of Southern Nevada
RobertScheitlin__GISP
Pete,
   Version 3.7.4 is now available.
Pete,
   I have to admit I have not done a lot of testing with multipoint data. Is your service public ally accessible? If not I will have to find some time to create some data and publish a map service for testing in my already very limited schedule for Flex.
PeterKohler
Hi Robert,
Thanks for the response. Here is the service that I am using…
http://gis.rtcsnv.com/arcgis/rest/services/Maps/TEST_MPO_InteractiveMap/MapServer/8
Again, thanks!
Pete
Peter,
   Thanks for the bug report and the map service to test this. The fix for this will be in the next version of the eSearch latter today.
Pete,
PeterKohler
Hi Robert,
Downloaded the new version, issue resolved. Thanks for the update! Much appreciated!
Pete
Peter,
Glad to help. Now it is your turn to help the community by marking this question as answered. All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you.
  If the answer was not provided by one of the responders then you can mark any of the replies that you received as helpful by clicking on the "Actions" menu and choosing "Mark as Helpful"
