eSearch widget and relates
6105
11
05-14-2015 08:54 AM
EricGardecki
Sorry if this is a stupid question but I searched and read many things and simply can't find an answer on this.
I know that I can view related tables in eSearch widget, but can I search data within the related tables (relationship class in this case) and therefore select the related feature based on that search using this widget?
thanks!
EricGardecki
Do you know of any other way I can accomplish this through the flex viewer?
Search on data in related table and select all of the features that had hits in the search result?
Maybe relates isn't even the answer for my issue...
Example:
I have a catch basin point feature class.  They will be inspected and I want to keep track of all of the inspections so I created a table for just the inspections and a one to many relationship class tying it to the feature class.  I want to be able to go in and get a map of say all of the catch basins that were inspected in 2014 or answer the question, which catch basins weren't inspected yet.  I thought this (relationship class to table) was the answer but if I can't pull out the info as described it won't work.  I can make it work in ArcMap but I want others to be able to do this through our flex app.
Any advice on how to best accomplish this?  I considered archiving (and no relates) but it's clunky to work with and still requires ArcMap.  Can the Query Widget or Attributes Table Widget help with this?
TasadduqHussain
Using Flex Viewer eSearch Widget 3.7
Want to add calendar on date filed instead of text value to be entered.
Please provide guidance.Screenshot is attached
