eSearch URL Not Working
6535
13
03-23-2015 07:03 AM
mpboyle
Honored Contributor
We recently migrated to a new ArcGIS Server that is using SSL and whose data sources for services are now using a local file gdb instead of our production SDE gdb.  One thing our Assessor's office uses is the eSearch widget to pass a search string in the URL to find a particular parcel by PIN number.  That no longer seems to work and I'm wondering what we need to do to fix it...
Example URL used: https://..../index.html?esearch=142830800200000
Is there something in the eSearch widget I need to update, or some other config.xml file?
Tags (1)
mpboyle
Honored Contributor
Thank you sir!
Sorry I don't know all the details about the config and version...as I said, I inherited it and am not familiar with what is all needed.
Do you plan on...or do you have a similar widget available for the Web AppBuilder?  Is there accompanying documentation?
RobertScheitlin__GISP
Sure,
Enhanced Search Widget Version 1.1.0.3
Help doc link is in the live preview site and in the widgets configuration page at "Learn more about this widget" link.
mpboyle
Honored Contributor
Does the eSearch widget need to be placed in the Web AppBuilder developer edition folder somewhere...?
Matthew,
  Yes the eSearch should go in the \client\stemapp\widgets\  folder
