eSearch Fixed Datagrid and opens on own
2362
01-22-2013 04:11 PM
RhettZufelt
MVP Notable Contributor
Hi Robert,
I have the fixed DG enabled in my FV31 app with popupsdisabled=true.
I also have some popups configured that have media (and tested with the OTB viewer adding the FDG).
If I click on a feature without media, no issues, however, the FIRST time I click on a feature that has media, not only does the infowindow popup, but the fixed DG pops up as well and will not auto-hide itself until I mouseover it.
From then on, it works as expected.  Only opens the (blank) fixed DG the "first" time I click a feature that has media in the popup, and works normal from then on.
Any ideas what/where would be casuing this?
R_
first noticed on 3.1.2, updated to 3.1.5 and still see it.
can reproduce on your eSearch example page if I go to traffic cameras and click on one.
RobertScheitlin__GISP
Rhett,
   Thanks for reporting this. I have had to do lots of workarounds because the esri popup is some how firing the move event in the FDG and I can not find out why or how... So here is the latest fix that seems to be working:
            private function addEvent(event:Event):void             {                 panelIsOpen = false;                 movingPanel = false;                 panelIn.removeEventListener(EffectEvent.EFFECT_END, addEvent);                 panel.addEventListener(MoveEvent.MOVE, panel_moveHandler);             }
Rhett,
RhettZufelt
That did it.
R_
RhettZufelt
Hi Robert,
Did you ever figure out how/where the popup is firing this move event?
Noticed this fix doesn't work in version 3.1.12.
R_
MattPohl
Hi Robert,
To say I am a bit frustrated and confused on the new "forum" would be an understatement. Because of that, maybe there is a much more recent post on this issue (it seems like maybe I too started a discussion on this way back when), but I finally got this post to come up while trying to search, and figured I would use it to post on. Anyways, I am experiencing the problem Rhett disscuss while using the 3.6 viewer and just wondering if there is a fix of any kind. Thank you Sir,
~Matt
Matt,
   Nope I have not seen this issue in the latest 3.6.9 version or the couple before that.
