eSearch ActionScript error on Selecting all on a 9100 records feature class
945
06-17-2014 07:38 AM
MichaelMiller2
Robert,
I have a service with a features class with 9100 records that I'm using in your eSearch widget. I'm using uniquevalsfromfield and the select "All" I receive the following error message about a Action Script timeout error.
I've also included a snippet of the XML configuration file for eSearch.
FV 3.6
ArcServer 10.2.2
Desktop 10.2.2
Any ideas on why this may be happening?
Error: Error #1502: A script has executed for longer than the default timeout period of 15 seconds.  at widgets.eSearch::eSearchWidget/getField()  at widgets.eSearch::eSearchWidget/createSearchResults()  at MethodInfo-93()  at mx.rpc::AsyncResponder/result()  at com.esri.ags.layers::FeatureLayer/selectFeaturesHandler()  at MethodInfo-3133()  at mx.rpc::Responder/result()  at com.esri.ags.tasks::QueryTask/handleExecute()  at Function/http://adobe.com/AS3/2006/builtin::call()  at com.esri.ags.tasks::BaseTask/loaderCompleteHandler()  at flash.events::EventDispatcher/dispatchEventFunction()  at flash.events::EventDispatcher/dispatchEvent()  at flash.net::URLLoader/onComplete()
 <layers>   <layer>    <token />    <definitionexpression />    <enableexport>true</enableexport>    <name>ADA Ramps</name>    <url>http://itdhq1app60/ArcGIS/rest/services/ADA_webEditing/ADA/MapServer/0    </url>    <expressions>     <expression alias="Select by Ramp ID"      textsearchlabel="Select Ramp ID from Dropdown (red asterisk = required)">      <values>       <value prompt="Ramp ID =" isvaluerequired="true"        uniquevalsfromfield="RampID">RampID = '[value]'</value>      </values>     </expression>     <expression alias="Select Ramps by District"      textsearchlabel="Select District">      <values>       <value prompt="Example: D1" userlist="D1,D2,D3,D4,D5, D6"        autosubmit="false">RampID LIKE '[value]%'</value>      </values>     </expression>           <expression alias="Full SQL Query"                 textsearchlabel="Enter Full SQL Query [Example: rampType = 'Parallel' AND county LIKE 'Koot%']:  See 'SQL Help' in Help Resources tool on Menu Bar for information regarding SQL Querys." >              <Values>                  <value>[value]</value>              </Values>           </expression>        </expressions>    <graphicalsearchlabel>Use one of the graphical search tools to select     Ramps    </graphicalsearchlabel>    <spatialsearchlayer>true</spatialsearchlayer>    <titlefield />    <fields all="false">     <field name="RampID" visible="true" gridfield="true" />     <field name="City" visible="true" gridfield="true" />     <field name="ClearSpace" visible="true" gridfield="true" />     <field name="Comments" visible="true" gridfield="true" />     <field name="ComplScore" visible="true" gridfield="true" />     <field name="Compliance" visible="true" gridfield="true" />     <field name="ConstYear" visible="true" gridfield="true" />     <field name="Corner" visible="true" gridfield="true" />     <field name="County" visible="true" gridfield="true" />     <field name="Cross1" visible="true" gridfield="true" />     <field name="Cross2" visible="true" gridfield="true" />     <field name="Cross3" visible="true" gridfield="true" />     <field name="Cross4" visible="true" gridfield="true" />     <field name="CrossIslnd" visible="true" gridfield="true" />     <field name="CrossSt" visible="true" gridfield="true" />     <field name="CrossStSl" visible="true" gridfield="true" />     <field name="CStRoute" visible="true" gridfield="true" />     <field name="CurbGutter" visible="true" gridfield="true" />     <field name="DateApprov" visible="true" gridfield="true" />     <field name="DimCorrect" visible="true" gridfield="true" />     <field name="Discont1" visible="true" gridfield="true" />     <field name="Discont2" visible="true" gridfield="true" />     <field name="Discont3" visible="true" gridfield="true" />     <field name="Discont4" visible="true" gridfield="true" />     <field name="Distance" visible="true" gridfield="true" />     <field name="Distance10" visible="true" gridfield="true" />     <field name="District" visible="true" gridfield="true" />     <field name="DWColor" visible="true" gridfield="true" />     <field name="DWContrast" visible="true" gridfield="true" />     <field name="DWDepth" visible="true" gridfield="true" />     <field name="DWSpansCut" visible="true" gridfield="true" />     <field name="DWType" visible="true" gridfield="true" />     <field name="Flare1A" visible="true" gridfield="true" />     <field name="Flare1B" visible="true" gridfield="true" />     <field name="Flare2A" visible="true" gridfield="true" />     <field name="Flare2B" visible="true" gridfield="true" />     <field name="Flare3A" visible="true" gridfield="true" />     <field name="Flare3B" visible="true" gridfield="true" />     <field name="Flare4A" visible="true" gridfield="true" />     <field name="Flare4B" visible="true" gridfield="true" />     <field name="FlowlineS2" visible="true" gridfield="true" />     <field name="FlowlineSl" visible="true" gridfield="true" />     <field name="GutterSl" visible="true" gridfield="true" />     <field name="GutterSl2" visible="true" gridfield="true" />     <field name="HalfinLip" visible="true" gridfield="true" />     <field name="Height15in" visible="true" gridfield="true" />     <field name="IComments" visible="true" gridfield="true" />     <field name="Inspector" visible="true" gridfield="true" />     <field name="InvBy" visible="true" gridfield="true" />     <field name="InvDate" visible="true" gridfield="true" />     <field name="IslandComp" visible="true" gridfield="true" />     <field name="KeyNo" visible="true" gridfield="true" />     <field name="LandDepth" visible="true" gridfield="true" />     <field name="Landing" visible="true" gridfield="true" />     <field name="Landing4x4" visible="true" gridfield="true" />     <field name="LandWidth" visible="true" gridfield="true" />     <field name="LocType" visible="true" gridfield="true" />     <field name="MarkCross" visible="true" gridfield="true" />     <field name="MaxSlope" visible="true" gridfield="true" />     <field name="Milepost" visible="true" gridfield="true" />     <field name="Milepost2" visible="true" gridfield="true" />     <field name="POINT_X" visible="true" gridfield="true" />     <field name="POINT_Y" visible="true" gridfield="true" />     <field name="ParkStrip" visible="true" gridfield="true" />     <field name="PedSignal" visible="true" gridfield="true" />     <field name="PhotoLink" visible="true" gridfield="true" />     <field name="PhotoLink2" visible="true" gridfield="true" />     <field name="PhotoNo" visible="true" gridfield="true" />     <field name="Priority" visible="true" gridfield="true" />     <field name="ProxScore" visible="true" gridfield="true" />     <field name="Ramp" visible="true" gridfield="true" />     <field name="RampApprov" visible="true" gridfield="true" />     <field name="RampAreas" visible="true" gridfield="true" />     <field name="RampDir1" visible="true" gridfield="true" />     <field name="RampDir2" visible="true" gridfield="true" />     <field name="RampDir3" visible="true" gridfield="true" />     <field name="RampDir4" visible="true" gridfield="true" />     <field name="RampType" visible="true" gridfield="true" />     <field name="RampWidth1" visible="true" gridfield="true" />     <field name="RampWidth2" visible="true" gridfield="true" />     <field name="RampWidth3" visible="true" gridfield="true" />     <field name="RampWidth4" visible="true" gridfield="true" />     <field name="RComments" visible="true" gridfield="true" />     <field name="Route" visible="true" gridfield="true" />     <field name="Route2" visible="true" gridfield="true" />     <field name="Running1" visible="true" gridfield="true" />     <field name="Running2" visible="true" gridfield="true" />     <field name="Running3" visible="true" gridfield="true" />     <field name="Running4" visible="true" gridfield="true" />     <field name="SegCode" visible="true" gridfield="true" />     <field name="SegCode2" visible="true" gridfield="true" />     <field name="Sidewalk" visible="true" gridfield="true" />     <field name="StRouteSl" visible="true" gridfield="true" />     <field name="TechInfeas" visible="true" gridfield="true" />     <field name="TIComments" visible="true" gridfield="true" />     <field name="TotalScore" visible="true" gridfield="true" />     <field name="TraffCtrl" visible="true" gridfield="true" />     <field name="Within8in" visible="true" gridfield="true" />    </fields>    <links />    <zoomscale usegeometry="true">5000</zoomscale>    <autoopendatagrid>true</autoopendatagrid>    <queryattachments>false</queryattachments>    <relates />    <symbology>     <picturemarkersymbol url="assets/images/map_pin.png"      height="50" width="50" xoffset="2" yoffset="23" />    </symbology>   </layer>  </layers>
RobertScheitlin__GISP
Michael,
  Unfortunately what you are attempting is just unrealistic. To have all 9100 features and attributes drawn and processed client side before meeting the Flash Players "Action Script timeout error" is just not going to happen.
Michael,
MichaelMiller2
Michael,
Thanks Robert. I expected your reply, but wanted to inquire.
