eSearch 3.1.4 Export Data Grid Results Issue
664
01-18-2013 03:03 AM
EricVenden
I have just upgraded to 3.1.4 of the eSearch widget.  I am encountering an issue where the data grid results do not export.  I can choose either the csv or txt format and then click on the "Export" button, but nothing happens.  This also happens when testing the previous version I used - 3.1.2.
I am also encountering slow response when closing the data grid window - probably a 3-5 second lag between the time I click the "X" and when the window actually closes.  I have tested on large and small results sets.
Any help is appreciated.
Eric V
Gurnee, IL
EricVenden
Looks like it is an issue with Chrome.  The issue does not occur in Firefox or IE.
I have enabled all pop ups in Chrome, still to no avail.  This is not a major problem (as of now) as there are only a handful of folks that use Chrome.
Eric V
RobertScheitlin__GISP
Eric,
   I tested this in Chrome 24 and I don't have any issue. But I have seen a lot of wierd stuff with chrome as Google has decided to add thier own version of Adobe Flash Player and by default use thiers instead of the one you have installed.
Here is a link to instructions on how to disable Google built-in Flash Player so that you can begin using the one you have installed from Adobe:
http://www.mytechguide.org/8173/disable-flash-completely-google-chrome/
