Error in Edit widget flexviewer3.2, flexviewer3.3
849
05-07-2013 11:34 PM
SuryaKant
I found two bugs in the Edit Widget listed below:
1) Select the feature on map and change the type in popup window then close the popup window( don't click on 'OK'). The feature will changed according to your recent selection.
2) Null object reference comes when the list item is selected and user click on undo or redo button. To get enabled undo/redo button, you need to perform any change on present feature or add new feature on map.
