Error for "apply buffer" on esearch
1617
02-25-2013 12:22 PM
MayJeff
I am using 3.1.9 version esearch.  When first click on "Apply buffer" button on Spatial Search I get error message instead of show me "There is no result to buffer, please make a graphical or text search first"
I tested on esearch website also got error message (http://gis.calhouncounty.org/FlexViewer3.1/index.html?config=config-eSearch.xml) but if you use this (http://gis.calhouncounty.org/FlexViewer3.1/index.html?config=config-eSearch.xml&esearch=2&slayer=3&e...) you will see the message.
Any ideas to change it?  Thanks.
RobertScheitlin__GISP
May Jeff,
   Thanks for reporting this. It will be fixed in the next release.
May Jeff,
   You have to have search results on the map before you can apply the buffer to them. That is what the message "There is no result to buffer, please make a graphical or text search first" is trying to tell you.
MayJeff
It works fine if you perform search first. The only problem if user accidentally click "Apply buffer" button then will get the error message.  It would be nice to show this message "There is no result to buffer, please make a graphical or text search first".
Thanks Robert!
May Jeff,
