Error: Error #2037 after upgrade from 3.3 to 3.4
2587
07-15-2013 09:54 PM
OlegLukyanov
Hi
I have error when start App Builder after upgrade to v. 3.4.
Error report from C:\Users\...\AppData\Roaming\com.esri.ags.AppBuilder3.0\Local Store\ab-log.txt in attachment.
7/16/2013 09:50:01.392 [INFO] com.esri.builder.controllers.RecentlyUsedURLsController Loading URL history
7/16/2013 09:50:01.251 [FATAL] com.esri.builder.controllers.ApplicationCompleteController Uncaught error: Error: Error #2037
Help please
Thanks
Juan_CarlosFranco
The log shows that the error is being caused by one of the modules being loaded at startup. Could you check if there is a particular widget that shows up in the custom widget list (under "Advanced Settings"), but not in the widget catalog (under the "Widgets" tab)?
OlegLukyanov
Hi
Sorry but I couldn't wait. I uninstall Flex Viewer 3.3 and install 3.4 again and it work.
Thanks
