error 2032
1796
07-30-2013 01:06 AM
ameeralkateeb
hi all ,
I want to use flex view 3.4 , data on my ARCGIS server 9.3 , I install adobe flash player & adobe air.
Note : both (server machine & flex viewer machine) are not connect to the internet
the server is working without any problem. I connect to server using flex viewer  and read the required map and layers ,
when I tried to preview error 2032 appear.
Note : I check the browser request there is error in crossdomain.xml file it tried to connect to adobe.com website.
I will be very thankfull for any help
DasaPaddock
Do you see any other requests that are failing? If it can't load the swz files from adobe.com then it should try loading them from your Viewer.
ameeralkateeb
Thanks for your reply
yes there are two fail request  in crossdomain.xml file and the swz  file ..
I check the file is created in the web folder but it not open from the web
what should I do
DasaPaddock
You need to enable your web server to serve the swz files. In IIS this can be done by adding them to the known mime types.
ChapalChoudhury
I get the same error message only for user accounts which do not have permission to Internet. After adding the SWZ to the known MIME types in the IIS, I'm still getting the same error message. Is there anythning else that need to be done after adding the SWZ file type?
