Error 2032
5505
24
02-21-2012 10:54 AM
AshleyPeters
All,
I receive error 2032 sporadically on my services when an application first loads. The error will clear if I refresh the page. I know others have had the same problem. Is there a resolution?
I'm using Windows Server 2008 R2 Standard.
Thanks!
Ashley
MattShetzer
Sad to say, I am still getting this 2032 error.  I'm really at a loss on what to do as I have tried all suggestions, but this intermittent error still occurs.  I never saw this error until I upgraded flexview to 2.4 and 2.5 and its really causing issues with my users as the get errors on the services as they load (normally the first time of the day)
Anyone from ESRI have any suggestions on how to resolve this error ?
Here are the steps I have taken now:
1. Modified the IIS settings on the HTTP Header to must-revalidate for the default website
2. Changed the Server to Periodically check and repair data connections for idle instance every 30 minutes
3. Restart all services at 6am daily.
4. Added .SWZ files to the Mime per the FAQ for ArcGIS Viewer for Flex
Thank you,
Matt
Thanks for the tip on the must-revalidate.  I was able to apply this to the Default Web Site without the error 500.  Hopefully this will be the fix.
Matt
AshleyPeters
I'm sorry that didn't help anything Matt. I'd suggest calling ESRI at this point. Good luck, I hope you get it resolved soon!
JasonNielsen
Thank you,
Matt
I've had the same troubles that you've had matt. I've tried all of the ideas people have posted on the forums but still get the error sometimes.  I can go a few day and everything works great and then for a few days it can crash, normally in the AM hours. It's not a specific map service that crashes its just seem to pick one at random. I'm on a Windows 2003 server with iis 6. We are upgrading to a new server with windows Server 2008 and the latest iis and i hope that will fix the troubles i've had with the 2032 error. Never had the problems till i upgraded to 2.4.
AshleyPeters
Just ran across this thread. Maybe it will help you:
http://forums.arcgis.com/threads/26850-Sleeping-Server-Services-slow-to-start
MattShetzer
Thanks for the tip Ashley.  I thought that might of fixed the 2032 error, but when I accessed the site this morning, I got the error again.
Matt
