One more thing. I changed the font size and style in the defaults.css file for the .WidgetTitle so that the Widget headings would be larger and easier to read. I noticed that your eSearch and Identify widgets did not change the title size. Do you have them configured to not react to that .css file?
Alex Sanders
Hello Robert
good news! We have solved!!!
I have set resultFillSimbol with empty fill and overFillSymbol with solid fill.
For draw fill in graphic when I click on it on result table I have write this code on clickSearchResult function (not in highlightDataGroupItem function because it is called only when I have selected datagrid float for theme):
var pt:MapPoint = searchResult.point;
var id:Number
id = searchResult.gid;
var gra:Graphic;
gra = graphicsLayer.graphicProvider[id] as Graphic;
gra.symbol = overFillSymbol;
For clear fill I have added this lines to unhighlightDataGroupItems function:
var gra:Graphic;
for (var ir:Number = 0; ir < graphicsLayer.graphicProvider.length; ir++)
gra = graphicsLayer.graphicProvider[ir] as Graphic;
gra.symbol = resultFillSymbol;
Robert, this work. Is it correct?
[Bindable]
private var _queryTitleField:String;
public function set queryTitleField(value:String):void
_queryTitleField = value;
