Enhanced Search Widget for FlexViewer 2.1
219316
767
10-25-2010 02:13 PM
RobertScheitlin__GISP
All Here is my next widget in the FlexViewer 2.1 series
Special thanks to Erwan Caradec for contributing to this code.
The Enhanced Search Widget extends the standard search widget with a floating data grid and a new spatial query w/buffering.
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
EricVenden
Robert,
See attached txt file - query string was:  SUB_NAME LIKE '%victorian%'
Eric
Eric,
    I think we are running into an issue here. To properly diagnose the issue we need certain things to remain constant in the debug process. So try the query again using this where clause:
SUB_NAME LIKE '%Southridge%'
and these outfields:
SUB_NAME,SUB_PHASE,SUB_UNIT,DOC_NUM,PLAT_PDF,OBJECTID
EricVenden
Robert,
See attached with the search criteria, etc as you had specified.
Eric
Eric,
   So for testing purposes plug this exactly into your SearchWidget.xml file and be sure to clear your browsers cache and try the query again.
  <layer>
   <name>Subdivisions by Name</name>
   <url>http://arcgis-srv1.village.gurnee.il.us/ArcGIS/rest/services/Subdivisions/MapServer/1</url>
   <expressions>
    <expression alias="Subdivision Search By Name" textsearchlabel="Search by Name [ Example: Southridge ]:" >SUB_NAME = '[value]'</expression>
   </expressions>
   <graphicalsearchlabel>Use one of the graphical search tools to select Subdivisions</graphicalsearchlabel>
   <spatialsearchlayer>true</spatialsearchlayer>
   <titlefield>SUB_NAME</titlefield>
   <fields all="false">
    <field name="SUB_NAME" alias="Subdivision Name" gridfield="true"/>
    <field name="SUB_PHASE" alias="Phase" gridfield="true"/>
    <field name="SUB_UNIT" alias="Unit" gridfield="true"/>
    <field name="DOC_NUM" alias="Doc Number" gridfield="true"/>
    <field name="PLAT_PDF" alias="Subdivision Plat PDF" gridfield="true"/>
    <field name="OBJECTID" alias="ObjectID" gridfield="true"/>
   </fields>
   <linkfield></linkfield>
   <icon isfield="false"></icon>
   <zoomscale>1200</zoomscale>
  </layer>
EricVenden
Robert,
I used the code you sent and the initial search popped the #1009 error, but the results grid displays the correct information.  I used "Southridge" as the search string.
see attached
Eric
Eric,
    Maybe we are trying to look to narrowly at this... Post your whole SearchWidget.xml
EricVenden
Here it is Robert,
I copied the xml from a search that we have working and tweaked it.
Eric
Eric,
   Try using this 2.2.5 version of the xml with your data plugged in for you.
EricVenden
Robert,
I tried the new xml with the same result.
Eric
Eric,
   As long as you cleared your browser cache to ensure that the new xml was used. I am completely out of ideas.
