eDraw 'Show Measurements' Bug?
2570
10
11-15-2012 04:55 AM
JasonStanton__GISP
I am trying to use the eDraw widget (v3.0.2).  When I enable show measurements only the point measurements are displaying.  Line & polygon measurments are not 'drawn'.  The only change I have made is changing the spatialref in the xml to reflect my base map/layers (26986).
I feel like the answer is painfully obvious, and that I will be apologizing for being so stupid, but I have tried a number of things to get this working with no luck.
Any thoughts?
JasonStanton__GISP
Robert,
I can't thank you enough for your assistance (again)!  I truly appreciate your time!
