eDraw error message
1659
10-24-2013 07:57 AM
MayJeff
I got an error message after try to edit the vertices for a polygon.  See attachment.
Thank you.
RobertScheitlin__GISP
May Jeff,
  1. What version of the widget are you using (Hold the Alt Key and click on the widget title)?
  2. What is the WKID of your map?
  3. What is the WKID that you have specified in your eDrawWidget.xml?
MichaelVolz
Esteemed Contributor
What is a complex polygon that you were trying to edit?
Was it a multi-part polygon?
I did not write the code, but I'm wondering if these types of polygons might cause this widget to crash.
MayJeff
Only draw a simple rectangle box then either move to different location or edit the vertices to change the size.  Other draw tools got the same error message too.
Thanks.
May Jeff,
MayJeff
I use version 3.4 on 7/25/2013, and both WKID on my config.xml & eDrawWidget.xml (<spatialref>102696</spatialref>) are the same.  I change this EPSG_GEOGRAPHIC to same as WKID and it works!
Thanks.
