Greetings,
I have been struggling to get this particular widget to work.
I have it so that it will display a pop-up box with the tools available.
However, there is no list of features to choose from.
It simply says: "select template to create feature"
I have tried placing the widget in both the widgetcontainer as well as UI elements - same thing.
I have tried using both dynamic and feature operational layers.
It seems like the only other thing that could be wrong is from the creation of the features, themselves.
I have made a polygon as a basemap, as well as blank point, blank line, and blank polygon features (which are to be the user-editable ones).
I have noticed that using the tools, I am actually able to do some editing of the polygon basemap, however, it also does not show up in the list under "select template to create feature."
I have since excluded this layer, as I only want users to be able to create things on top of the basemap.
Is it not enough to simply create features. Looking at the feature template in ArcMap edit menu, it appears to be the same thing as creating features the traditional way.
What could I be doing wrong?
