Edit Widget
1214
08-27-2013 09:45 PM
ameeralkateeb
I installed ArcGIS Viewer for Flex 3.4. The operational layers were from our ArcGIS Server. But the Edit widget shows "No editable layers". What should I do to make editable layers available?
the operation layers are from SDE dataset (all my layers coming from SDE)
AnthonyGiles
Honored Contributor
Ameer,
When you published your operational layer have you turned on feature access:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Publishing_feature_services/01540000033700...
Regards
Anthony
ameeralkateeb
thank you .. editable layers is appear now 🙂
the save button in edit widget is not appear (save on server).. what should I do ??
AnthonyGiles
Honored Contributor
Ameer,
Not sure what you mean by the save button does not appear, I have not seen any save button on the flex edit widget, changes are automatically saved to the server.
See the example here:
http://resources.arcgis.com/en/help/flex-viewer/live/index.html?config=apps/config-edit.xml
Please do not forget to mark this post as answered.
Regards
Anthony
ameeralkateeb
Thanks again Anthony,
I mean in my local system when I add a new point it not saved in the layer .
Note : operation layers are from SDE dataset (all my layers coming from SDE)
