Edit Widget - 'No editable layers'
1123
12-10-2011 10:28 AM
MatthewWhitehead
I am trying to use the edit widget.  I'm using PostGRE with ArcSDE.  I turned versioning 'off'.  And gave all permissions to 'public' user using the 'privileges' tool.  When I try to run the edit widget it says I have no editable layers.  All services have feature access.  In my config file it reads.
<operationallayers>
         <layer label="Other Assets" type="dynamic" visible="false" alpha="1.0" url="http://virginislands.cnr.ncsu.edu/ArcGIS/rest/services/590mcwhiteh/mcwhitehOther/MapServer"/>
            <layer label="Nutrition Locations" type="dynamic" visible="true" alpha="1.0" url="http://virginislands.cnr.ncsu.edu/ArcGIS/rest/services/590mcwhiteh/mcwhitehNut/MapServer"/>
            <layer label="Grocery Stores" type="dynamic" visible="true" alpha="1.0" url="http://virginislands.cnr.ncsu.edu/ArcGIS/rest/services/590mcwhiteh/mcwhitehGro/MapServer"/>
            <layer label="Public Schools" type="dynamic" visible="true" alpha="1.0" url="http://virginislands.cnr.ncsu.edu/ArcGIS/rest/services/590mcwhiteh/mcwhitehPub/MapServer"/>
        </operationallayers>
My services displayed fine but still no editable layers.  Using another forum post to help I change the config to read:
        <operationallayers>
            <layer label="Nutrition Locations" type="feature" visible="true" alpha="1.0" url="http://virginislands.cnr.ncsu.edu/ArcGIS/rest/services/590mcwhiteh/mcwhitehNut/FeatureServer"/>
            <layer label="Grocery Stores" type="feature" visible="true" alpha="1.0" url="http://virginislands.cnr.ncsu.edu/ArcGIS/rest/services/590mcwhiteh/mcwhitehGro/FeatureServer"/>
            <layer label="Public Schools" type="feature" visible="true" alpha="1.0" url="http://virginislands.cnr.ncsu.edu/ArcGIS/rest/services/590mcwhiteh/mcwhitehPub/FeatureServer"/>
Still no editable layers and now the services are not displaying on the map.  Any help in this matter would be appreciated.
IvanBespalov
Matthew,
just open links and try to fill the difference:
Feature Service
Feature Layer
