Delete vertex not available when editing
3202
11
10-03-2011 12:57 AM
LukeEvans
I am using a heavily modified version of the Flex Viewer.  Whenever using an editor within our implementation I am unable to right click to delete a vertex.  I have tested this in the out of the box version and it works fine.  I cannot figure why this option would not be available to me.  I have 'allowDeleteVertices' set to true.  We use the EditTool rather than the Editor component.  Does anyone have any ideas as to why this option wouldn't be available in the context menu?
Luke
MarkNewcomb
Was this issue ever resolved?  If so, how?
I tried the suggestions above but nothing seems to work with EditTool and EditTool.activate doesn't have the enableGraphicsLayerMouseEvents parameter.
When I activate EditTool, I lose the map.contextMenu and instead get the application ContextMenu over the map and therefore no Delete Vertex option.
When I deactivate EditTool, I get the map.contextMenu over the map again.  I believe that is due to setting enableGraphicsLayerMouseEvents to true when activating Pan.
How do I get the Delete Vertex using EditTool?
Mark
MarkNewcomb
I integrated my code with ArcGIS Viewer 3.0 for Flex and the problem is solved.
Mark
