crossdomain
3386
04-18-2012 10:01 PM
Chamaraprasanna
what is crossdomain.xml ? What it do? Is there  any things  between OGC WMS and crossdomain.xml ?
any idea!
IvanBespalov
Chamara,
Form adobe: Cross-domain policy file specification
A cross-domain policy file is an XML document that grants a web client�??such as Adobe Flash Player, Adobe Reader, etc.�??permission to handle data across multiple domains.
From ArcGIS API for FLEX help: About using crossdomain.xml
To access data from a different server other than the one hosting your Flex application, the remote server needs to have a cross-domain file in the root directory.
From ArcGIS FLEX Viewer help: Getting Started
If this service is not running in the same web server, your ArcGIS Server will need a crossdomain.xml file.
Your ArcGIS server (or any other used server) must return http://server.arcgisonline.com/crossdomain.xml
or
use proxy.
