configuring map switcher widget
861
07-25-2012 09:02 AM
NadeemQazi
Hi
I want to  customized my arcgisview application for flex. I have made the application using the arcgis viewer for flex 3.0. I have three maps layers which are shown in Map switcher widget. I want  to following
1. the widget should only show the my layer names i.e i want to hide all the layers name in it
2. The default name of the basemap  in the widget should be changed
I tried to change the config file of the widget but it did not work. I tired following code.
Is there any way that i can also use this map switcher widget to take input and based on that input show the content of the selected layer.
Any help is appreciated.
Regards
Nadeem
