Complied Flex API does not display images
1064
05-31-2013 11:40 AM
by Anonymous User
Not applicable
I am unable to view any of the icons for my widgets in my Flex app.
Map services shows up fine in the app. I am able to navigate to the location of the icons without any issues. I tried using Fiddler, but it does not give me any error messages ?
Any thoughts on how I can troubleshoot this issue ?
Thanks!
Phoebe
ChristopherBlinn1
Phoebe,
Are you modifying the Flex Viewer code or building your own application?
If you are working with the Flex Viewer code, it will be a little easier to figure out what the issue may be.
If not, we will need some code to show how you're creating your widget container and container items.
Chris B.
by Anonymous User
Not applicable
Hi Chris,
I started modifying the existing FlexViewer code. The code was not built by me so I don't have too much information about it.
I removed the viewSourceURL property on the <mx:Application> tag and tried to complie  the code. When I right-click on the widget box, I now get a 'Print' option. If I exit the Print option window, the widgets will show up.  I am not sure what is causing this behavior.
Phoebe
