Clustering in viewer 2.4
6314
21
07-30-2011 11:56 AM
BjornSvensson
Esri Alum
It hasn't made it in to the <layer> tag documentation yet, but there is a sample called "Clustering" listed on the "Samples" page.
Here are some examples of how to take advantage of the new <clustering> functionality in flex viewer 2.4.
Basic example:
<layer label="Simple, same-sized circles (default color green)"
           type="feature"
           url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/MapServer/0"
           popupconfig="popups/PopUp_311.xml"
           visible="true">
        <clustering>
            <clustersymbol type="simple"/>
        </clustering>
</layer>
The example from the online sample:
<layer label="San Franscisco 311" type="feature" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/MapServer/0" popupconfig="popups/PopUp_311.xml" visible="true">
    <clustering mingraphiccount="2" sizeinpixels="80">
        <clustersymbol type="simple" alpha="1" alphas="0.7,0.8,1" bordercolor="0xFFFFFF" color="0xFF4242" colors="0xFF837E,0xFF4242,0xFF4242" flaremaxcount="10" size="90" sizes="30,60,90" textcolor="0x000000" textsize="14" weights="10,100,200"/>
    </clustering>
</layer>
DerrickMartin
    </clustering>
Trying to patiently wait for the updated documentation. But, can you give a brief description of what each of these settings is doing? Also, are there any other configuration options available for the clustering?
IvanBaehr
Thanks for a great new feature!!
I have three questions to clustering in flexviewer 2.4
1. When I zoom to max zoom level I still have some features clustered. Which parameter will I have to set to ensure that features will be displayed as single points when zoomed in?
2. Does flare working with clustering for flexviewer 2.4?
3. Does <linkfield> to images work for Popup window for clustered layer? When I mouse click on single points in the clustered layer for popups I only get the url displayed not the image.
Ivan Baehr
UNOSAT
EvanCaldwell1
Hi Ivan, I'm also working through this and have been able to figure out some of the properties.
1. Increasing the property minigraphcount (try 5 or more) should reveal those final few points when zoomed in.
2. Set clustersymbol type="flare" (this works, but is not currently supported because it has not yet been fully implemented)
3. You need to configure a custom popup.xml for the feature layer. Check the <medias> tag in the viewer documentation.
Hope this helps!
-Evan
Ivan Baehr
UNOSAT
IvanBaehr
Hope this helps!
-Evan
Thanks Evan for your help. This brought me a step further. I simply had not set clustersymbol type correct to "flare" and had not configured <media> correct for imagesource. Now it works.
Still I face the problem that some points are still clustered a maximum zoom level and thus may not be displayed by popup window. Are popup not working for the flared points.
In addition to this I don't succeed getting popups to work for dynamic layers. As I understand the documentation for Flexviewer 2.4 the new popups should work for tiled, dynamic and feature layers???
Ivan Baehr
UNOSAT
IvanBaehr
I found the solution for popups with dynamic layers using sublayers. The new popups are just amazing. Sometime reading carefully the ArcGIS viewer for Flex documentation is really a very good place to start... 🙂
Ivan Baehr
UNOSAT
JosVroegop
I can't get a popup to work on flared points either, is there something i am doing wrong?
<layer label="Test Clustering" type="feature" visible="true"
     popupconfig="popups/PopUp_SR_Ultrasoon.xml"
     url="http://gistest.railinfra.local/ArcGIS/rest/services/US_Data/MapServer/0">
        <clustersymbol type="flare" alpha="1" alphas="0.7,0.8,1" bordercolor="0x000000" color="0xFF4242" colors="0xFF837E,0xFF4242,0xFF4242" flaremaxcount="10" size="90" sizes="30,60,90" textcolor="0x000000" textsize="14" weights="10,100,200" />
       </clustering>
     </layer>
Thanks in advance.
BjornSvensson
Esri Alum
No, you're not.  This isn't supported in the current release, but is something we are looking at for version 2.5.
JosVroegop
Ah, so I can stop trying now, haha. Thanks for the info!
KennethLyons
does the clustering not work for "dynamic" layers?  I have been able to make the sample data work in my viewer, but when I try to apply it to some of my real data it does nothing.  The only major difference between the 2 that I've been able to see is the "type" in the sample data is "feature" and in MY data is "dynamic".  Any help with this would be great.
