Cannot add custom widget in Flex Application Builder
563
03-15-2013 03:22 PM
LisaArnold
I am trying to add a custom widget in the Flex Application Builder. When adding I receive the following error: "Custom widget import failed: Cannot transfer module and widget files to template folders: Error #2038". In searching I haven't found any info on this error. Has anyone else run into this or have any suggestions on how to resolve this? At first I thought it was happening with only the enhanced search widget, but I have tried it with several others and I receive the same error on each. I am using Application Builder 3.1. I tried reinstalling the Applcation Builder but still have the same issue.
What's odd is when I go back in to the Application Builder later, I see them custom widgets I tried to add are actually there, but it shows a broken link image for the icon, and when I go to edit the widget in the Application Builder the Widget Settings screen only shows <configuration/>, and not all the xml.
Thank you.
