can th Width of Pop-up Window be changed?
2320
05-11-2013 06:02 AM
ThomasColson
Using Flex 3.2 on ASrcGIS 10.1 with a dynamic map service, I configured a pop-up to show related records. When the pop up is activated, it sizes correctly to show feature attributes, however, when showing related records, the columns are truncated and only a portion of the related record attribute columns are shown (cut off vertically). There appears to be no way to click-drag-resize the pop up window. Is there a way to alter the size of the pop up window so that contents will not be truncated? I hope this  is possible without having to write code in Flex and compile, which we do not have the ability to do (no access to Flex Dev tools).
ScottMcGee
Tom,
Flex 3.3 solves this problem.
I had the same issue with 3.1 and 3.2. I upgraded to 3.3 and it solved it. However, rather than increasing the width of the related records window, the update adds a scroll bar which lets you scroll horizontally to see the complete record.
Scott
