Buffer Distance Widget Stuck
591
11-02-2012 12:03 PM
PaulVincent
In my flex api application, I'm trying to add the Buffer Distance widget.  When I execute the widget on the application, it indicates that it is buffering on the form (rotating circle with "buffering.." text), but it appears to be stuck on this buffering process.  I have an esearch buffer widget that works normally, but I can't get the Buffer distance widget to work.  Whether I set the spatial reference to the esri default or my WKID, I get the same results.   I'm using API 2.5 with ArcGIS 10.0.  Anybody have any ideas how to solve this?
RobertScheitlin__GISP
Paul,
   Have you changed the geometryservice url in the BufferDistanceWidget.xml? Are you using a 10.1 geometryservice?
Are you using spatialReference 102100 or 102003 like I had originally in the XML? If you are using 102003 than switch to 102100 instead.
BTW this forum is for the Flex API and there is a Flex Viewer forum specifically for widget and viewer questions:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
