Buffer disappears after search is complete i (enhanced search 3.4)
977
11-08-2013 10:39 AM
PATRICIACOSMOPOULOS
Hi there,
I am having a issue with the spatial search in the Enhanced search widget (Flex viewer v3.4). Once a search is complete and a buffer is created when we select "completely contained" or one of the other options in the buffer the widget provides the new results while the buffer disappears. Is this something i can fix or is it just part of the widget's behaviour? I find it is helpful for the user to see where the buffer is in case they need to correct or pick a larger buffer. In version 2.5 the buffer was visible when the results appeared. Any help would be appreciated.
Patricia
RobertScheitlin__GISP
Patricia,
   This is the intended behavior as I received many requests to have the buffer graphic removed once the search is complete (you seem to be the first to mention wanting it the other way around). If you are working with the source code you can changing it back to the old behavior.
